Variable width living hinge pattern in sketch?
Hi All,
I'm currently experimenting with living hinges in various laser cutting designs. I would like to make a living hinge pattern that expands or varies in width depending on the sketch elements. It seems like it should be relatively simple to do in a sort of parametric pattern, but I'm struggling with how to do it in Fusion360. I've made a simple example for this post. I would like to make a simple living hinge pattern where the width of the individual lines in the sketch expands/varies depending on the contour of the part. I've attached photos. I would like to make so the horizontal cuts of the living hinge are equal length (per row), but each row width can vary. I know I can 'brute force' it by manually constraining each row, but I figured there could be a smarter way?
Hope you're able to help or point me in some direction, thank you!
