Announcements
Using Combine>cut
brad.bylls
Using Combine>cut
brad.bylls
When I use combine>cut, I can only pick one target body.
Is that the only option?
I have a tool body that needs to cut more than one target body.
Do I have to run the combine command multiple times?
Brad Bylls
g-andresen
YES
YES
Please share your design!
File > export > save as f3d locally  > attach it to the next post.
günther
This appears to have been running for a while.... so I thought I'd nudge it.
https://forums.autodesk.com/t5/fusion-360-ideastation-archived/select-more-than-one-target-body-comb...
I have an assembly that is formed from multiple parts, it seems nonsensical that I should have to cut them individually or combine them prior to cutting?
Surely there is a huge demand for this feature?
