Using a sketch to cut 360 along an axis - like doing a "Revolve" but maintaining both parts?
NVNDO
Message 1 of 10
NVNDO
I hope I explained it well enough ^^
Im basically trying to do a revolve cut along the line I created to split the body into to pieces and color them accordingly. Though I was not able to do that with just a line.. I then created a closed sketch with I then could select but I can't get it lo work like I wish.
Basically like this, but maintaining the cut part.
How do I do this..?
Replies (9)
Message 2 of 10
g-andresen
please share the file for reply
file > export > save as f3d on local drive > attach to post
günther
Message 3 of 10
jhackney1972
Sounds like a you want to use the "Split Body" command.  This will split the body and retain both sides for you to use or "Remove".  You can make your sketch parametrically rotate around the center is needed.
John Hackney, Retired
Message 4 of 10
g-andresen
create  a revolved surface and use it as tool for split body
günther
Message 5 of 10
NVNDO
@g-andresen
Thank you soooo much!!
I didn't add the file thinking that I just missed a basic feature somehow.
I had never ever used "Surfaces" before - as I never had the need to.
Worked great and a nice addition for future works 😄
Message 6 of 10
NVNDO
I have not gotten this to work yet as I don't know how to make the Split-Body function turn.
But I will give google a search. Its always good to have alternative solutions.
The other day it took me over 6 hours to make one simple thing. I tried at least a docent different ways of which none worked - giving me all different kind of errors - the last try and only idea I had left eventually worked.
Thank you for helping out!
Message 7 of 10
jhackney1972
The video will show what I was thinking about using a parametric sketch for a Split Body Function.  Model is attached.
Message 8 of 10
NVNDO
Message 9 of 10
g-andresen
1. define a revolve axis
2. revolve surface body
3. split body
günther
Message 10 of 10
NVNDO
Oh wow... that's pretty interesting. I don't yet have a use-case for such a cut, but whenever the time comes, probably sooner than expected - I will remember know. Thank you 😄
