@mgrauZ237M Fusion 360 license is assigned to an e-mail address and not to a specific PC. Once activated, it does need to be transferred to a new machine.
To be able to use the active license on another computer:
- Install the Fusion 360 Desktop Application on the new machine (see: How to install Fusion 360)
- Once the software is installed, log in with the e-mail address to which the license is assigned.
- Fusion 360 will start. (Provided you have logged out from the previous machine. If not, a message will appear, through which you can terminate the previous machine instance)
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
