Announcements
USD FILES 변환이 안됩니다.
USD FILES 변환이 안됩니다.
Error: System username or Fusion 360 installation path contains unsupported characters. Install Fusion 360 under a username and path that contains only ASCII English characters.
위와 같은 이유로 되지 않습니다. 혹시 사례가 있다면 해결 방법을 알려주세요
lance.carocci
Hi @Anonymous,
I'm sorry you are having this experience. Just to confirm, you are saying that Fusion 360 is already installed, and it is the process of exporting a USDZ file that causes this error? Is this on Windows or macOS, and what version?
Would you be able to please send me the installation path for your Fusion installation? Additionally, let me know the directory path that you were trying to export to. (You can privately message this to me if the path contains personally-identifying information, but we need to know the impacted characters.)
The easiest way to find Fusion's installation path on Windows is to right-click Fusion's shortcut icon, click Properties, and copy what is listed for the "Target:" field.
Finally, please provide log files from Fusion, which may help us identify the issue.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
lance.carocci
Hi @Anonymous,
After investigating this issue, it sounds like this is actually a known limitation of the USD file format itself, as it is still somewhat under development. We do not know when this might be resolved by the developers of the USD format, but will update to support the latest standards once available.
Lance Carocci
