Announcements
Usage Limits Exceeded" when trying to save or create a new project
noycegmi
noycegmi
I have been using fusion 360 now for a while trough the various maker and trial licenses over the years I just switched to a personal use license but now I get usage limits Exceeded if i try to save or create a new project. could you please check my account.
g-andresen
watching  this tutorial might help
günther
noycegmi
I currently only have 3 of 10 editable documents but still cannot make a new project in either the data panel or web based interface
jhackney1972
Take a look at this Forum post and try the two mentioned solutions.
John Hackney, Retired
noycegmi
I used both methods and still can't create a new project. I can create new folders, documents, and save in existing projects. I have attached a copy of the diagnostic log as well.
jhackney1972
If you have just begun to use a new Fusion 360 Personal License, then you may need to create a Team Hub.  Even if you just a single user, you still have to create and work inside a team.  This article will help you create a new Team.  Afterwards, open up your Fusion 360 Data Panel and make sure you have selected your new team and then I believe you will be able to create a new Project  I have attached a screen capture of where you select your Team once created.
jhackney1972
I am wondering if my last suggestion, on creating a Project, help you solve your issue?  If so, please select the Accept Solution icon on the post that solved your issue, otherwise, ask for further help.  It is nice to know our work helped you out but we only know if you respond back.
