For the the last two days I am having problem with "...unable to validate a security certificate..." error message. I am also having problem with Fusion 360 is not responding just after signing in.
I tried to find solution on different forums but without luck.
I changed proxy settings to "no proxy" and it did not help. I reinstalled fusion 360 couple of times but it also did not help. I uninstalled norton product to be sure it's the cause of my problems but I got the same result.
I looked into logs and found the following error:
20220221T234606 E 3288 Network failed request - response NOT OK:
URI:https://developer.api.autodesk.com/fhq/v1/spaces?type=FLC&fusionId=
...X-Request-ID: ContentBrowser_3abda75a-7f1d-40a6-bf44-47defad8d965__GET_FLC_URN_GET_FLC_URN
...response: HTTP/1.1 400 Bad Request
Connection: keep-alive
Content-Length: 419
Content-Type: application/json
Date: Mon, 21 Feb 2022 22:46:06 GMT
Strict-Transport-Security: max-age=31536000; includeSubDomains
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
{"requestId":"ContentBrowser_3abda75a-7f1d-40a6-bf44-47defad8d965__GET_FLC_URN_GET_FLC_URN","httpStatus":400,"detailedMessage":"Error while trying to Process Request. Please check if Input has all valid parameters specified","errors":[{"type":"errors","code":"FHQ-400","message":"Validation Error: must not be empty . At getSpaces.fusionId","links":{"self":"https://developer.api.autodesk.com/fhq/v1/errors/FHQ-400"}}]} ThreadID: 3288, Function: void __cdecl Ns::Network::ReqUtils::logRequestError(const class std::basic_string<wchar_t,struct std::char_traits<wchar_t>,class std::allocator<wchar_t> > &,class std::shared_ptr<class Ns::Network::Request>), Line: 322
20220221T234606 W .4524 FHQService: failed to get FLC URN, response code:"
I found very similar issue on forum but it was related to multiple displays. I am using single one so obiously that's not the case. I am attaching log file with mentioned error. Maybe it will help.
Kind regards,
Piotr
