Announcements
Upper half of my Fusion 360 window is appearing black.
Message 1 of 8
Black screen is appearing on the top of working area(where commands are visible) in my Fusion 360 window. I reinstalled the program and again face the same issue. Earlier it was working fine but after I disk cleanup my C drive, I am facing that issue.
Replies (7)
Message 2 of 8
dsouzasujay
Hi @Anonymous ,
Could you please try adding the environment variables.
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 8
I have tried that solution but it doesn't work for me.
only changing the language works... but I'm not good at french nor german....
Message 4 of 8
dsouzasujay
Hi @Anonymous ,
After adding Environment variables did you restarted machine?
Can you please share me the screenshot of the Environment variables?
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 5 of 8
thanks for the quick reply.
First I tried software, then the angle, I rebooted every time before I tried again.
I would love to send that screenshot, but I have no admin rights and I have to bother our IT guy (who lives in another country) to log in with teamviewer to change a setting...
Right now it is set at angle
Message 6 of 8
It's fixed:
since I have no admin rights, I had an admin to log in with team viewer. so the variables were set for the user: administrator.
Once we set the variables for the system instead of user, fusion is back on track!
Message 7 of 8
dsouzasujay
Hi @Anonymous ,
Good to know now it's fixed.
Also the information related to Admin will be useful for us.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 8 of 8
Changing Environment Variable worked for me. Thanks for your help.
