Fusion Support
Uploaded files, not opening.
5 REPLIES 5
mbupp
233 Views, 5 Replies
Trying to upload and open a SLDPRT file, I've done this hundreds of times in the past year on this same computer with no issue.
File -> Open -> select file on my computer. Wait for Upload to finish -> hit Open. Other than today this always opened the sldprt file and I could work from there. Today I hit Open and F360 refreshes the screen, and nothing appears on the screen.
I took the file to another PC that has another seat and uploaded the file there, it worked as it should so the file is ok. Since I saved the model in fusion I can now open it on this PC as well I then tried to upload and open older sldprt files I have previously worked with on F360 and they have the same issue. So it seems I cannot open the file I uploaded on this PC only.
I tried rebooting pc and in F360 to go to Help -> Service Utility -> Reset Fusion360. Neither has made a difference. Haven't tried a full reinstall, hoping for other options.
5 REPLIES 5
HughesTooling
in reply to: mbupp
There is another post about this and that workflow is broken at the moment! I you use Upload in Fusion's data panel instead of Open it should work.
Mark Hughes
Owner, Hughes Tooling
mbupp
in reply to: mbupp
Thanks, appears to be a work around. Odd that it works on one of my PC (separate seats) but not the other
requestsVCUR2
in reply to: mbupp
This doesn't work for me.  I have been fighting this all morning.
adam.selfCMJJ7
in reply to: mbupp
Has this been resolved? I'm having the same issue.
requestsVCUR2
in reply to: mbupp
not yet....  If I go to the Data panel and search for the uploaded file in the search box, I can find it.
