Upload progress bar stuck and won't go away
FrodoLoggins
FrodoLoggins
Usually when it gets stuck refreshing/going to another folder/project makes it go away:
Went away after restarting Fusion.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
RajkumarIlanchelian
@FrodoLoggins Are you still experiencing the issue? I see this in your post - "Went away after restarting Fusion."
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
FrodoLoggins
After restarting Fusion the progress bar went away until I tried uploading that file again.
Looks like it only happens on this one STEP file that is 0 bytes [file attached but renamed] so it's probably a corrupt file or something.
EDIT: The file won't attach to this post for some reason.
But if you want to get to this issue that priority is much higher. The solutions provided did not resolve that issue. Can't keep clicking on drop down menus a hundred + times a day:
https://forums.autodesk.com/t5/fusion-360-support/drop-down-menu-bug/m-p/12330204#M184712
