Updating folded sheet metal body with changes made in flat pattern
rdosh
rdosh
I made a couple of changes while in flat pattern (a relief cut and split a body) and, before I made many more changes, wanted to make sure that the changes were appearing in the folded model. In fact, they did not. What do I need to do to get the model to update?
Fusion archive attached.
g-andresen
1. Modify > Unfold
add or edit features
2. Refold
3. Flat pattern
günther
rdosh
Well, I unfolded and created the circle with which to make the relief cut. The problem now is that, in the cut operation, I cannot get it to select the bend. It can select both bends but omits the bend.
g-andresen
might help
günther
rdosh
Thanks, Gunther! I had to play with it a bit but I got it to work.
rdosh
Gunther, it now seems that splitting the body is now preventing me from refolding the model. I'm wondering if I missed some step in the solution that you provided.
