Update to 2.0.10244 Failing to install
jpjones2
jpjones2
System: OS X Big Sur 11.4
I haven't had an update failure for a couple of years, until now.  The update to 2.0.10244 fails with messages in the log like the following.  The same errors show up in the log ever time I start Fusion 360.  Any ideas how to get past this?
2021-06-04 19:08:48,977 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.diff - ERROR :: Failed to apply patch to target <snip>/Library/Application Support/Autodesk/webdeploy/production/fe3fcaf80332a5029e937468546464598d153f1a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/ProcessSimulation/Solver/bin/libDryboost_program_options-1.61.dylib.patchout with patch file <snip>/Library/Application Support/Autodesk/webdeploy/production/fe3fcaf80332a5029e937468546464598d153f1a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/ProcessSimulation/Solver/bin/libDryboost_program_options-1.61.dylib and original file <snip>/Library/Application Support/Autodesk/webdeploy/production/ba559ff8dcd36132ff7536db7476ebf75121d655/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/ProcessSimulation/Solver/bin/libDryboost_program_options-1.61.dylib
2021-06-04 19:08:48,979 - MainProcess(98838) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.diff - ERROR :: Failed to apply patch to target <snip>/Library/Application Support/Autodesk/webdeploy/production/fe3fcaf80332a5029e937468546464598d153f1a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/libADFlowPluginInterface.dylib.patchout with patch file <snip>/Library/Application Support/Autodesk/webdeploy/production/fe3fcaf80332a5029e937468546464598d153f1a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/libADFlowPluginInterface.dylib and original file <snip>/Library/Application Support/Autodesk/webdeploy/production/ba559ff8dcd36132ff7536db7476ebf75121d655/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/libADFlowPluginInterface.dylib
2021-06-04 19:08:48,989 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to apply patch: Error creating or applying patch: Cannot rename data file to output file
2021-06-04 19:08:48,989 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Manually cancelled current thread <Future at 0x7fa6e0f78510 state=running>
2021-06-04 19:08:48,989 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Thread <Future at 0x7fa6e0f6fcd0 state=running> is still running and can not be cancelled
2021-06-04 19:08:48,989 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Thread <Future at 0x7fa6e0f78c50 state=cancelled> is cancelled
2021-06-04 19:08:48,989 - MainProcess(98838) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Thread <Future at 0x7fa6e0f78d90 state=cancelled> is cancelled
2021-06-04 19:08:48,994 - MainProcess(98838) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Failed to apply patch: Error creating or applying patch: Cannot rename data file to output file
2021-06-04 19:08:48,995 - MainProcess(98838) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Manually cancelled current thread <Future at 0x7fa6e0f6fcd0 state=running>
2021-06-04 19:08:48,995 - MainProcess(98838) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Thread <Future at 0x7fa6e0f78c50 state=cancelled> is cancelled
2021-06-04 19:08:48,995 - MainProcess(98838) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Thread <Future at 0x7fa6e0f78d90 state=cancelled> is cancelled
2021-06-04 19:08:49,012 - MainProcess(98838) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Appending update of 70c2f727e1a3a97d4102b3f21bf4b7301564004b
jpjones2
I downloaded and ran the installer.  Now Fusion 360 is completely broken.  I get a dialog:
Autodesk Fusion 360 cannot be opened because of a problem.
Clicking "Report", I see the following:
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
dyld: Using shared cache: 4A889CE9-8D7E-304E-A5F7-84D819B0BF9C
Library not loaded: @rpath/Qt/QtCore.framework/Versions/5/QtCore
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Reason: image not found
