Update stops at ~59%
erikpeterson72
erikpeterson72
Hi, I've had several update attempts fail at ~59%.  Restarted F360 and also the entire PC several times, no change.  I have the diagnostic log, attached.
RajkumarIlanchelian
@erikpeterson72 I see this error in the logs:
Exception in Update [Errno 28] No space left on device
Can you check disk space and also see if you can clear out your tmp location as well?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
erikpeterson72
Hmmm, it appears that F360 has hijacked a lot of C-drive space, which is not where I want it to install. Do you have any tips for installing to a different Drive letter?  I have a lot of capacity, just not in C.
RajkumarIlanchelian
@erikpeterson72 Unfortunately at this time our install is dependent on the C drive. I am. checking with our install team if there are any alternatives but almost sure there is none.
Autodesk Fusion
Join Fusion Insider
erikpeterson72
Thank you very much for the information, please let me know if you find any way to do installs somewhere other than c drive, as I view that as a flaw. I will mark this as resolved because the fault does lie in drive space available (even though that should not be an issue), but please DM or reply here if you have any workarounds to the default install drive.
Thanks for the help.
sikandar_ilyas
Hi @erikpeterson72 ,
Can you please let know how much space left in your C:\ drive? I am assuming you have not yet cleared any space in C:\ drive.
Ideally Fusion360 should have alerted that sufficient space is not available for installation before starting live update but that did not occur in your case.
Regards
Sikandar
erikpeterson72
Not much space left at all, and F360 was 13.3GB I'd like to move to a different drive.
