Fusion Support
Update Keeps Failing
2 REPLIES 2
ejohnson43EDQ
92 Views, 2 Replies
Hello, I have tried restarting my computer and that hasn't helped. My internet connection is not the issue.
2 REPLIES 2
@ejohnson43EDQ I have adzes our engineering team to look at the logs. Can you please restart your machine in the meantime to see if that helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Hi @ejohnson43EDQ ,
Are you using a wi-fi currently for internet connection? It seems this issue may result from a unstable internet connection.
If possible can you please switch to ethernet cable to connect to internet before starting installation?
Regards
Sikandar
