update failed
I have restarted the computer multiple times and still failed to complete update.
Hi @salesFUL6L
Sorry to see that you're facing this problem.
Could you please follow below article and see if the problem get fix?
Repair Fusion 360 from Fusion 360 Service Utility
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaWas not able to repair. It says server problem WinError3.
Hi @salesFUL6L
I saw 2 sessions of Fusion 360 started almost simultaneously. Currently I don’t have idea what may cause this situation.
Can you please try
If you still not able to Launch Fusion 360 then please share latest autodesk.webdeploy.streamer.log
Sujay D'souzaI tried to uninstall multiple times but it doesn't uninstall.
When you say 'doesn't uninstall'. Does the uninstall process starts? do you get any error message while uninstalling?
Could you provide more details?
Sujay D'souzaThe uninstall process starts, a fusion 360 window flashes and disappears and there is no error message.
Hi @salesFUL6L
If you still have problem uninstalling Fusion 360 then try install again after remove folder %localappdata%\autodesk\webdeploy
Hope this works for you.
Thanks.
