Update error
Update error
toretto_88
Update error
toretto_88
Good afternoon! Fusion 360 doesn't want to be updated.
sutherland-
Hi @toretto_88
First, try this troubleshooter form to help solve the most common issues for Fusion 360 failed updates.
Alternatively, follow the manual steps below:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
toretto_88
I have solved the problem with launching the program. But there was another problem the view cube is not displayedСнимок-23.PNG
Sketches are not created.
sutherland-
Does this help?
P.S. If my previous reply solved you issue, please press "Accept Solution" since that will help other users fix the same issue that you are facing. 🙂
Best regards,
Level  sutherland-
Member
