Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Update a derivative of a part in a assembly
tobii1998
Observer
Observer
tobii1998
Observer
Observer
before Fusion 360 I used other CAD-Sofwares like SolidEdge or Solidworks. There, I usually create a part and add it to a assembly. So if I change the part but doesn´t save it, it will nevertheless automatically update in the assembly. When I try the same procedure in Fusion 360 (create a derivative of a part), I can only update the assembly, when I saved the part to a new version. Can I change that in the settings or is that not possible?
Thank you for your help!
jeff_strater
that is not possible.  You must save a design before a referencing design will know that it is out of date.
Jeff Strater
Engineering Director
TrippyLighting
Do you understand the differences between a derived component and a linked component?
tobii1998
Observer
Observer
So far for me is the important difference between the derived and a linked component that I can´t make an update in the derived component without opening it and save as a new version. On the other hand I can change the linked component directly in the assembly. Is that what you meant?
