Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Update a derivative of a part in a assembly
3 REPLIES 3
tobii1998
228 Views, 3 Replies
before Fusion 360 I used other CAD-Sofwares like SolidEdge or Solidworks. There, I usually create a part and add it to a assembly. So if I change the part but doesn´t save it, it will nevertheless automatically update in the assembly. When I try the same procedure in Fusion 360 (create a derivative of a part), I can only update the assembly, when I saved the part to a new version. Can I change that in the settings or is that not possible?
Thank you for your help!
Tags (1)
3 REPLIES 3
jeff_strater
in reply to: tobii1998
that is not possible.  You must save a design before a referencing design will know that it is out of date.
Jeff Strater
Engineering Director
TrippyLighting
Do you understand the differences between a derived component and a linked component?
tobii1998
in reply to: TrippyLighting
So far for me is the important difference between the derived and a linked component that I can´t make an update in the derived component without opening it and save as a new version. On the other hand I can change the linked component directly in the assembly. Is that what you meant?
