Fusion Support
Unwanted hidden detail lines
6 REPLIES 6
rstQSMSM
222 Views, 6 Replies
Hi
If anyone out there can advise me why am I seeing the extra hidden lines in my top view.  3rd Angle Ortho.  See attached drawing.
Rob
6 REPLIES 6
HughesTooling
in reply to: rstQSMSM
The lines look like phantom lines you get when a sketch is made visible in the drawing browser. Is a sketch visible in the browser? If it's not this can you share the part?
Also please paste\embed pictures as it makes it easier to read and view.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
If it is hidden lines have you tried disabling them? Double click the view and try changing to visible only.
Mark Hughes
rstQSMSM
in reply to: HughesTooling
Thanks Mark. Unfortunately that didn't work but I did try something along the lines from above message. Cheers Rob
rstQSMSM
Hi Mark
I changed the lines you see in blue from solid to dashed and then saved the model.  Opened the drawing, did an update and they have disappeared.
Thank you
Rob
HughesTooling
@rstQSMSM wrote:
Hi Mark
Thank you
Rob
That indicates you have the sketch set to visible in the drawings workspace browser (like I show in my first reply). Construction lines in a sketch do not show, only normal lines will show as phantom lines if a sketch is visible.
Mark Hughes
rstQSMSM
