Announcements
unstable sketches
moritzLCGFK
unstable sketches
moritzLCGFK
Hi everyone,
I’m working on a cabinet system where 1-3 fronts can be stacked on top of each other. The center of the cabinet is always at the origin, so the cabinet grows both upwards and downwards. This setup is critical for the way I built this  design, so I hope that´s not the main problem.
For the attached video/file, I’ve removed all unnecessary elements, leaving only the foundational sketches.
The issue: When switching between different configurations (e.g., different numbers of fronts), Fusion fails to solve certain dimensions. If I delete the problematic dimension and reapply it with the exact same value, everything works again—until I change the configuration once more, and the issue reoccurs.
Does anyone know what might cause this problem and how I can resolve it?
Thanks in advance for your help!
sameer_babarNJS6C
@moritzLCGFK
Sorry for the inconvenience caused & Thank you for sharing the files. I can reproduce the issue at our end with file provided by you . Our team will analyse it further more.
We have logged an issue FUS-184824 for it & we are looking for the solution .
Sameer Babar.
Autodesk Fusion Team
