Announcements
Uninstall error - -2147417850 Cannot change thread mode after it is set
wjlahr
wjlahr
Community Visitor
Community Visitor
Attempting to uninstall fusion 360.  I get:
[WinError -2147417850] Cannot change thread mode after it is set
Not much else to go on.
Rushikesh.kadam
@wjlahr Refer to the article on how to perform an automatic clean uninstallation and then reinstall. Try to uninstall using it.
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
wjlahr
Community Visitor
Community Visitor
I ran the cleanup utility but it was still in the 'Add or Remove Programs' in windows.  I tried running the install again so I could uninstall it and get the same error.
Rushikesh.kadam
@wjlahr can you try to do a manual clean uninstall using the steps mentioned here? It also mentions how to remove Fusion 360 from the 'Add or Remove Programs'.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
