Unfold bug
dcAWMGX
Unfold bug
dcAWMGX
Hi
There seems to be a bug in the latest insider build when trying to unfold a simple sheetmetal part with a cut in the flanges. I can accomplish the same cut in different ways so can get around the issue right now, but it need to be fixed.
jhackney1972
Fusion 360 Insider Edition questions do not below on this Forum.  Please post an problem reports on the Inside Website.
John Hackney, Retired
dcAWMGX
Well i found out it´s also a problem in the regular version. and as it has nothing to do with the features that is worked on in the inside build the forum said to post it here.
jhackney1972
I only reacted to what you posted.  The file is useless to this Forum as it was created with the Fusion 360 Insider edition and has a different schema, it cannot be opened by the current "public" version of Fusion 360.
dcAWMGX
John,
I updated the post with a file from the standard version.
g-andresen
edit your sheet metal rule
günther
