Unexpected behavior in user parameters, 1.5 ft does not equal 18 inches
Hi all,
I have encountered an issue with user parameters where 1.5 ft apparently does not equal 18 in. To calculate the number of studs needed to fill a wall, I am using the length of the wall divided by the stud pitch. A robust formula will be more complicated than that, but it's the starting point. However, there seems to be a difference between the expressions:
floor((BuildingLength) / (1.5 ft))
and
floor((BuildingLength) / (18 in))
with the top expression returning 17 and the bottom expression returning 12 for the same fixed value of the variable BuildingLength. I've also tried replacing BuildingLength with a fixed value and the delta persists.
I'm running v2.0.9719 (Fusion 360, Personal) on Windows 10. Any help would be greatly appreciated, seeing this delta reduces my trust in more complex expressions so for now I'll be manually validating the results of everything until I understand what's going on.
Thanks!
EDIT: I realized that I neglected to post the screenshots of the variable window.
