Announcements
Undocking from external display causes loss of modal dialogs
tarheel_cnc
tarheel_cnc
On my windows 10 Lenovo X1, I often connect to a 5K display and disconnect to manufacture on my CNC or move to a different room.
When I am on my laptop display after having started or used Fusion 360 on my larger display, the modal dialogs in design and manufacture mode are often off screen (they cannot be found).
I would do a video, but all you would see when I extrude or edit sketch or edit a toolpath, etc. is that the modal dialog is not on the screen
My current fix is to save everything, exit Fusion 360, start F360, and re-open my designs.
Is there a way to fix this?  Is there a way to reclaim the modals when they are lost (presumably off to the right of the current more narrow screen)?
Or maybe a way to force the modal dialog to always be in the tree view where Browser is?
Mark
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @tarheel_cnc
At first, you can look at this article: Parameter or other dialog is missing in Fusion 360
If this doesn't help you let me know and I will try to find some other solution for your issue.
Piotr Kornafel
Global Product Support
 Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
tarheel_cnc
The proposed solution does not work for most f360 dialogs.  I have used the proposed technique with windows from other programs and actually tried it several times on the subject dialogs before posting.  Thank you for offering it as a suggestion to try.
Change parameters is an actual first class windows 10 window with a title bar "Parameters" across the top, so it is a different dialog than the ones I am describing (alt-spacebar brings up restore/move/size/minimize/maximize) context menu.
Edit sketch and other dialogs lack the windows 10 window context options / move option.  If I try the suggested key sequence when editing a sketch where the sketch dialog is lost, for example, the f360 move object dialog appears in response to pressing the M key.
Only Fusion 360 knows about this dialog, so I think that fusion 360 needs to register for some OS monitor/display change notifications and act accordingly (or it needs to poll every once in a while for monitor/display dimension changes / perhaps when rendering a modal dialog)
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @tarheel_cnc
I will look around for some solution for you, I hope that I find something.
For now, you can look at this forum topic about a similar issue:
Browser window and toolbar automatically move to the middle of the screen
What's more, you can describe your issue here as an improvement request:
New Ideas for Fusion’s Dialog
If I find something that can help you I will let you know if not we need to post this to Fusion 360 Feedback Hub and wait for an update.
Piotr Kornafel
tarheel_cnc
Reset to default layout appears to solve the problem and I pretty much use the default layout, so I will go with that for now.  It would be nice if this was fixed in the future for other users.
File -> View -> Reset to Default Layout (Ctrl-Alt-R on windows)
