Announcements
UNABLE TO VERIFY SECURITY
daveaburnham
daveaburnham
Screenshot CAM.pngon my fusion 360 started to run extremely slow all of a sudden. then i started to get this warning. im not the best with computers and this doesn't make sense. my network isn't running a proxy and i allowed the required files access thru  my fire wall as in structed bye solutions that i read. definitely need help. i will attach log files
thanks
lance.carocci
@daveaburnham I can see some SSL errors in the logs that are likely causing this message. Would you please confirm that you don't have any proxy settings configured for Windows, or perhaps any background traffic inspection/firewall apps that might be trying to route Fusion 360's traffic?
You can access Window's Proxy settings simply by typing "Proxy" in the Start Menu, or locating it under Windows' Settings app. Generally speaking, if you have no proxy configured, then the settings should look similar to the screenshot below (Automatically Detect Settings may or may not be enabled - you can try toggling it to the opposite setting).
Windows 10 proxy settingsWindows 10 proxy settings
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
