Announcements
Unable to upgrade, version already installed
it
Observer Observer
it
Observer
Observer
Hi All
Fusion 360 is warning a user on a laptop that an update is needed by 14th July. The running version is 2.0.8809 so OK, it needs updating.
If I download the client installer and run as admin, the install fails because the latest version is already installed.
If I login to Windows as admin and run Fusion 360, the running version is 2.0.10356.
I'd be happy to start over but the upgrade fails and I can't uninstall the current version as Windows doesn't list it as being installed in the first place. There are other Autodesk products installed too (AutoCAD, Inventor) but Fusion just doesn't get a mention.
Before I wipe this laptop and go from scratch, does anyone know of another option?
Thanks in advance
Rushikesh.kadam
@it can you perform a clean uninstall of Fusion 360 and try to reinstall?
The below links explains how one can do an automatic clean uninstall of Fusion 360.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Here are some related troubleshooting links for a similar problem.
  1. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Lat...
  2. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
If my reply was helpful, please click the "Accept as Solution" or the “Like” button. This helps others to find the answer more quickly!
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
g-andresen
Future reference:
Fusion installs the updates automatically if there is an internet connection. If it does not work, it is advisable to remain calm and wait 1-2 reboots before resorting to the Clean Uninstall.
günther
