Hi, I need to uninstall Fusion 360, but I keep getting the same error when I use Control Panel:
Can not find script file C:\Users\cybah\appdata\local\autodesk\webdeploy\meta\uninstall.wsf
I need the space at the moment so I do need to uninstall, but the Autodesk help files only show you how to manually uninstall by using the Control Panel. I've downloaded, extracted and used the automatic uninstall software, but that only clears the cache. I'd appreciate help please with this problem
Stewart
