unable to sign in
2110230UBCL
unable to sign in
2110230UBCL
i am unable to sign in. Uninstalled and installed a couple of times, still same issue. I had requested the same few days back and it didn't help.
Please look into in asap.
jhackney1972
What is your operating system?  Are you using a Chromebook?  You need to attach your Fusion 360 logs.  If you do not know how, take a look at this web page. Once you have them attach them to a reply post.
John Hackney, Retired
2110230UBCL
hi i did find the logs. however i didnt understand the attaching logs.
jhackney1972
In a reply Forum post, you will see an Attachment section,  use this to select and attach the log file.  Do not forget to tell the Forum your operating system.
2110230UBCL
windows
dooyoul_chung
Hi @2110230UBCL
Thank you for attaching log file. Please give a try again after run Fusion Service Utility "Reset Fusion 360".
Hope this helps.
