Announcements
Unable to select sketch contraints, pattern etc
Growingwiththem
Growingwiththem
Hello I am unable to select patterns and certain things like horizonatal constraints, I can select a perpendicular constraints, I have this problem accross multiple different files.
It has suddenly stopped working I can select a newley created pattern but not ones I was using and selecting earlier with no problem.
I have tried turning on and off the selection priorities and restarted fusion with no fix.
Below is an example file, its a pretty simple sketch which I have attached I cant select the patterns or horizontal constraints.
Version: 2.0.11186
Active Plan: Fusion 360, Student
Windows 10 (19043)
TheCADWhisperer
Turn off/on constraint visibility.  It should then work.
This is a bug.
Growingwiththem
That worked thank you
jeff_strater
I think this is the same issue as reported here:  unable-to-select-sketch-contraints-pattern-etc
Thanks for reporting it.
Jeff Strater
Engineering Director
