Fusion Support
Unable to select mesh to repair .
2 REPLIES 2
carlbroker
185 Views, 2 Replies
Attempting to follow this tutorial - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-merge-me...
Am unable, due to lack of `Mesh` tab in my preferences.
I'm trying to select a mesh to both repair, then reduce.
Thanks!
P.S. Image for awesomeness.
Labels (7)
2 REPLIES 2
@carlbroker
It appears that you have the top level of the assembly active rather than the model_0 component.
Furthermore the model_0 component is an external link...
Make the external component active - what do you see now?
@carlbroker
The support page you linked appears to be out of date with the current version of Fusion...
BTW - I wouldn't expect much luck with the mesh that you have in your image.
