Unable to select lines and spline handles.
Recently Fusion has been giving me random problems and can't figure out if it's me or something changed. I Have reset the preferences but still running into randomly not being able to select lines or spline handles. I have 6 components I am working on a 6th with the 6th component selected, is this correct, should I be working from the top route component instead? I'm only a couple months in on Fusion. I also use construction lines then drew a box within the construction line but it wouldn't close so couldn't extrude it, lot's of weird things like this is happening even after resetting preferences. Maybe I clicked something, or computer is the problem or a glitch in something? I'm at a loss and have to get this work done.
I attached a small video.
Much Appreciated.
Found it. Selection filters had bodies only on Doh.
