Fusion Support
Unable to select a sketch to loft/extrude
5 REPLIES 5
sebastien_privat
262 Views, 5 Replies
I have made a sketch I can't extrude or put in a loft.
It seems closed to me (I viewed it with max zoom at the points I joined different parts of the sketch and found no discontinuity).
All the points seem coplanar (they all have the same Z coordinate I wanted them to have).
I have checked for multiple lines and haven't found any.
What could cause such a behaviour?
TIA,
Sébastien
5 REPLIES 5
please share the file
File > export > save as f3d on local drive > attach to post
günther
check to be sure that "show profile" is on for that sketch:
Then, use "divide and conquer" (drawing extra lines in the sketch) to see if there is a "leak" in your profile somewhere
Jeff Strater
Engineering Director
Thanks for your reply.
I don't get the "divide and conquer" bit, could you please elaborate?
Here's my model, the sketch I'm struggling with is the latest one.
TIA,
Sébastien
Parts of the sketch are outside the sketch plane.
Move to sketchplane is your friend.
günther
It is indeed my friend.
Thanks a lot.
Sébastien
