I had problems with Fusion not launching properly / only launching after multiple tries, restarts.
Sometimes it wouldn't start at all, then if it did start, usually only the UI loaded, the 3D modell did not.
Because of this, I decicded to uninstall, and then reinstall fusion.
I couldn't uninstall Fusion the regular way (Fusion service utility also wouldn't work), so I decided to delete Autodesk's forders in the AppData, OneDrive folders.
Now I'm unable to install Fusion. I've attached the error message, and the log files bellow.
Link copied
