I had problems with Fusion not launching properly / only launching after multiple tries, restarts.
Sometimes it wouldn't start at all, then if it did start, usually only the UI loaded, the 3D modell did not.
Because of this, I decicded to uninstall, and then reinstall fusion.
I couldn't uninstall Fusion the regular way (Fusion service utility also wouldn't work), so I decided to delete Autodesk's forders in the AppData, OneDrive folders.
Now I'm unable to install Fusion. I've attached the error message, and the log files bellow.
Solved by RajkumarIlanchelian. Go to Solution.
@banatibencea Can you go to :
1. C:\Users\(username)\Appdata\Local\ Delete the Autodesk folder
2. Also on your desktop please delete the shortcut launcher
3. Restart your machine
Try install again.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you, it worked.
There was an issue with OneDrive, which didn't allow the Fusion shortcut to be deleted.
@banatibencea Glad to know this worked.
Autodesk Fusion
Join Fusion Insider
