Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Support
Unable to reinstall after the repair tool removes Fusion from my PC, "leftover files" error
2 REPLIES 2
Bansheeboy11
195 Views, 2 Replies
Ive now spent hours today trying to insert a small STEP file into 360, which led to the repair tool unsuccessfully removing 360 from my PC and now im getting a leftover files error from the web launcher when trying to reinstall. Autodesk took away pretty much everything from the free accounts last year, now i pay for the full program and have nothing but problems. The installer wants me to delete a WebDeploy folder thats 30gb. Any help would be appreciated!
2 REPLIES 2
@Bansheeboy11 That is the folder where the installer drops in all the needed files. However we expect this to be in the 8-10Gb range.
You can safely delete that folder and try to install again. Did you try a restart of the machine to since often times that does solve a lot of these kinds of issues.
on a different note you mentioned "which led to the repair tool unsuccessfully removing 360 from my PC". Is my understanding that you could not insert a STEP file and you did the repair to see if that will fix it?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Bansheeboy11
in reply to: Bansheeboy11
Hello, i did delete the file which allowed me to continue the reinstall and the software seems to be working correctly.
