I have downloaded the personal use fusion 360 and am going through the training videos via coursera. While learning how to add new versions of a design they talk about using the promote button to promote the first version to the most current version. I do not have the promote button on my version list. I did make sure to update fusion 360 to the most current version and it still is not there. Not sure if I have something set up wrong or what is the issue.
Thank you.
Solved by jhackney1972. Go to Solution.
Take a look at this article from Autodesk. The Promote option has been changed.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
