Unable to open
David_Wimmer
Observer Observer
Unable to open
David_Wimmer
Observer
Observer
I am unable to open my project file.
This is the Error message:
Opening previous versions also fails.
Restarting the software does not resolve the issue.
RajkumarIlanchelian
@David_Wimmer Its likely that you are on an older version of Fusion than what this file is saved in. Please do the following.
1. Go to Fusion - Help - Check for updates - If it finds the update, proceed with the update and then this should be taken care of.
Now for any reason it tells you do not have an update then please do the following:
1. Close Fusion
2. Delete the shortcut that you launch Fusion
3. Go to add/remove program
4. Select Autodesk Fusion - MODIFY
This will launch the Fusion service utility
5. Run the repair Fusion from here
This should now tak
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
David_Wimmer
Observer
Observer
Thank you for your solution suggestion.
This did not seem not to work. The Fusion version was recently updated. The solution i found working, was a new install. For some reason it was also only this project, as I tried multiple other ones. Maybe it was open while updating or something like that.
Anyway it is solved now, thank you for you help and the great products!
