Since starting up this morning I can not open one particular file, other files I have been working on open correctly. Also previous versions of this file do not open. The file as well as the diagnostics log is included for your information .
A lot of work has been put into this file, I hope you can help me.
Solved by dveusa. Go to Solution.
Solved by HughesTooling. Go to Solution.
Have you tried opening the file you uploaded in your post? I downloaded it but changed its name to temp.f3d and it opens but complains about missing reference files.
Try changing the name of the file like I did and upload it to the same project the original design ( EDIT you might need to change the file type to f3z as well) is in and try opening it. If it still wont open it might be a problem with the inserted reference designs, do they open OK?
Mark Hughes
Owner, Hughes Tooling
