Unable to open large assembly
Since todays update (2.0.15775) I am unable to open a large assembly
I get the following error
The path C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_D1-11 Camera Chassis PCB Board.5ea4ceed-1d9b-4c3b-888f-17a4e1cc765d_LV0.f3d is not a valid zip package.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_D1 Assembly.21496150-dd43-488a-b87d-5ce5206da19b_LV0.f3d could not be loaded.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_D Assembly.86315615-a9ab-4bc3-8613-bc4586e397c5_LV0.f3d could not be loaded.
The path C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E1-03 Controller Box Windows PC.947e62b3-435c-4095-84d0-1bb42d1bbb2c_LV0.f3d is not a valid zip package.
The path C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E1-02 AG-003-REVC.9dc6b386-1760-4b1a-a987-3cf84daafe52_LV0.f3d is not a valid zip package.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E1 Assembly.dffece93-c6b1-420d-a4cb-4ce7abce4c0e_LV0.f3d could not be loaded.
The path C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E5-06 Keyswitch Blanking Plate.96d177a0-d079-46d4-a4b7-0d2a2ea28a47_LV0.f3d is not a valid zip package.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E5 Assembly.eaff6c1f-1cfc-4094-a059-d5cb7e3e27e2_LV0.f3d could not be loaded.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_E Assembly.1bdaf414-eda6-4891-835b-023f4a7c9a0b_LV0.f3d could not be loaded.
The path C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_B3-03 Flexible Chain Top Bracket RH.e4010ef2-12a1-42f8-a7ec-1efb592b8698_LV0.f3d is not a valid zip package.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_B3 Assembly.0dae2a5e-d7dd-4d2b-836a-49f6d11ce1cc_LV1.f3d could not be loaded.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_B Assembly.f13fb33b-af88-4085-8b54-d551a8e32cb5_LV1.f3d could not be loaded.
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_XRef_/_Complete machine Compact.7d679eba-3f9f-4204-9077-9ee78adcdaa7_LV2.f3d could not be loaded.
Could not find referenced document: _Complete machine Compact.7d679eba-3f9f-4204-9077-9ee78adcdaa7.f3d
The file C:/Users/mikel/AppData/Local/Autodesk/Autodesk Fusion 360/XP6VPJWKLYQS/W.login/F/_layout 1.8fb0b827-daaa-45be-aabd-9cd0ea6ed20f.f3d could not be loaded.
I have tried clearing the cache but the error remains the same.
regards
Mike Lerwill
