Unable to open, it may not have synced correctly - NOT EAGLE RELATED
ovisopa
Message 1 of 9
ovisopa
Hello everyone,
I seen this error in the past but not so often, but today, I tried to open 2 files I created Friday but none worked, both files show the same error.
The files are just some 3D models made from an imported dxf file, and then I did the CAM part in the Manufacturing module, to have the parts milled on my mill. There is no electronics components, nothing to do with Eagle in any of those models.
I attached the log file of one file
Replies (8)
Message 2 of 9
ovisopa
Is this just me, or there are other people with this issue? I now have another model I started on my home PC a few days ago, and now while I'm at my  workshop I can't open the file, quite weird is that the file on the web opens just fine (I enabled SHARE LINK now after I noticed I can't open it on my other PC)
https://a360.co/3fdROgi
I'm the only one experiencing this bug?
Message 3 of 9
CGBenner
@jeff_strater @Phil.E
Any ideas?
Chris Benner
Industry Community Manager – Design & Manufacturing
Message 4 of 9
Phil.E
This could be related to an issue we are testing a fix for. Try going offline, using the offline toggle in the Job Status dialog box, and then open the design (assuming it is loaded into recent local cache).
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 9
jeff_strater
I can open the downloaded file OK.  If you are still stuck, download a copy, and you should be able to open it as well.
Jeff Strater
Engineering Director
Message 6 of 9
Phil.E
Make sure both machines are on the same version of Fusion. The current build number is 2.0.14569.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 9
ovisopa
from time to time I get this when I turn on fusion, I chosed Ignore until now
Today I pressed YES and it showed this error:
The Fusion version I have at my workshop PC is 2.0.13162
No updates are pending
This file was created friday on this computer , I tried to open it but it doesn work, nomatter if I keep Fusion online or Offline
Message 8 of 9
Phil.E
The current build number is 2.0.14569, which is months ahead of your computer on that old version.
On that machine, use the service utility to repair Fusion 360.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Ove...
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
ovisopa
I tried now to press CTRL+SHIFT before and untill fusion launched, the service menu didn't show up but I see a new notification that fusion was updated, and it seems now I'm at the latest version 🙂
I will post again if the main issue is not resolved.
Thank you!
