Unable to make a sliding as built slide joint
I have down loaded to STL files for a project I will be printing and building. The designer of the cnc machine has only released the STL for the printed parts and no modal of the complete machine to work with. I am trying to make a model of the machine so I can use it to build other parts and a work table I want to add to it.
The problem I'm having is I have imported the STL models into my model and designed the other parts I need. I'm at the stage where I want to had slider joints on the components so I can simulate the moving parts but when I select the STL component it doesn't allow me to build the slider joint.
what do I need to do to make a slider joint work?
