Unable to lauch or repair
phchfruk
phchfruk
I have not used F360 for a few months.  At launch I now get an error message suggesting a reset.  I tried that- no difference.
I have also done the network check and reset my modem.
I have deleted the files in the register, as suggested elsewhere in this forum.
Next, I tried F360 repair which fails at 99% progress.  The log is attached.
Thanks for your help.
jhackney1972
If you do not have any other Autodesk applications installed, you can follow the instructions in this Forum post.  If you do, change it a bit and only erase the Autodesk Fusion 360 folder in the mentioned directory.  Pay close attention to the fact you will need to download a new installer application from your Autodesk Account page.
John Hackney, Retired
phchfruk
This worked perfectly. Thanks.
