Announcements
Unable to extrude
mmaters_mm
Unable to extrude
mmaters_mm
Folk,
See video. Not sure what's going on here. The Sketch is fully defined. When I extrude I can see it appear, but when I OK the extrude it disappears, see video.
Anybody got an idea?
Kind regards,
Martin
g-andresen
Did you try the option „New Body“
please share the file for reply
File > export > save as f3d on local drive > attach to post
mmaters_mm
Thanks for your prompt reply.
I've tried New Body as well. No error messages and no "new body".
Kind regards,
Martin
jhackney1972
The indicated Circular Pattern is missing a body to pattern so it caused the error.  I do know know what you are trying to pattern but if you eliminate this pattern the extrusion in question will work.
John Hackney, Retired
mmaters_mm
Wow..... indeed, that was odd.
Very much thanks for your support, it was obviously very helpful! 🙂
mmaters_mm
ps. I'm a bit of a noob/newbie using Fusion.... (perhaps quite obvious), it's great to have a community like this!
