Unable to extrude Text - even though it worked before
As seen in the video, it worked before on the 3 text lines above, all the settings are the same.
Error message: Error: There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
I also added the f3d file, for you to be able to reproduce the error.
Font: Cambria
p.s: Excuse the sound in the video, I forgot to mute it.
g-andresen
I have tried several times with varying success.
Then I converted the text into curves with "Explode" > Voilà.
günther
Screencast
