Announcements
Unable to download personal use - Button doesn't work
I logged into Fusion and it tells me that my license has expired. I try to go to the page where it is for free personal (non-commercial use), and fill in the form, and check the license agreement box, but the download button doesn't do anything. I've tried Chrome and Edge. I see a captcha logo at the bottom, but am not presented with a captcha.
Help.
Thanks.
Michael
Replies (26)
uebergangster
Dude, having the same problem.
uebergangster
Try clearing your browser cache and then logging in to renew the licence.  I think this worked for me.  Suddenly I was looking at a totally different web page where everything magically worked.
I tried clearing the browser cache, using a different browser, logging out of the account, logging into the account. I've just been stuck. I understand that Autodesk needs to make money, but $500 a year for a couple of trivial personal projects seems pretty unreasonable.
uebergangster
Make sure you are logged out of Fusion also.  I also used a different computer in the process somewhere,  Who knows.
Whelp, they must have done something. I went to another and googled the personal license. It took me to a new page I hadn't seen before, and asked me to log in. I attempted to log in, and the page got stuck.
I then closed the browser, and tried again, and this time, it presented me with the download link (and I was logged in properly). Now when I go to the product and services page, all of the apps are properly listed showing personal use.
I mean it's really hard to complain, as it's free. I would be happy to pay a personal use license fee, but $500 year is just too much for me making stuff for my HO train set.
Thanks.
M
Same here,
Download Button doesn't work. Tried different things nothing happens, after click on Download the Button swapped to Log In????
uebergangster
I tried a few different things and suddenly it just worked. Sadly I can't
remember what I did. It's a pretty hopeless setup and autodesk don't seem
interested.
s026hoque
Can verify, this issue is still occuring. I believe this is autodesk intentionally being shitty.
<a href="#" id="submitbt" class="cmp-button wd-button pc-brand wd-btn-large wd-uppercase"><span class="cmp-button__text">NEXT</span><span><svg class="wd-icon"><use xlink:href="/content/dam/autodesk/icons.svg#icon-svg-cta-go-arrow-small"></use></svg></span></a>
The next button is just linked to '#'
vasileios.giannaris
Use VPN (simple vpn as opera's build in, works fine), select USA-america, then sign in again, do the same steps and should work. For me at least it works (Greece-Europe)
ola.ingvarsson
Community Visitor
Community Visitor
Thanks for the tip. Worked for me from Sweden.
hannu.taskinen
Observer
Observer
I managed to do this by going to canada's site https://www.autodesk.ca/en/products/fusion-360/personal
craig_fleming
Observer
Observer
Same problem tried 3 different browsers
vefCLNG6
Community Visitor
Community Visitor
I managed to download the software through the Canada web site. Thanks !
ParCoar
Observer
Observer
I can't remember how, but I ultimately was able to do it.
James.Youmatz
Autodesk Support
Autodesk Support
Hi all,
We are investigating what may be going on in the Personal sign up form that is causing this. In the meantime, if you are trying to sign up or renew and need access, please email me at james.youmatz@autodesk.com and provide the email address that you use for your Autodesk Account. I will manually grant the personal license while we investigate.
Thank you all for your patience!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
James.Youmatz
Autodesk Support
Autodesk Support
Hi all,
We believe we have fixed the issue. Can you please try again and let me know if you keep running into issues?
James Youmatz
emteepeeess
I am having the same problem - have created an account, gone to the personal page, filled in my details, but the NEXT button just keeps reloading https://www.autodesk.co.uk/products/fusion-360/personal-form#
James.Youmatz
Autodesk Support
Autodesk Support
Hi @emteepeeess ,
can you try in an incognito browser? We pushed a fix out and it appears to be working. If it is still not working, please let me know and I will manually assign it.
James
James Youmatz
emteepeeess
Actually, replying to James.Youmatz (boy this forum software is a bit flaky) ... I've responded via email, and incognito mode allowed me to download the installer - but, rather than coming up as a personal plan, it says "trial ends in 30 days".
