Unable make user parameter stick on the quantity field of a pattern on path feature
Picante1
Picante1
I am unable make user parameter stick on the quantity field of a pattern on path feature.
When the parameter it is first entered the path on path feature, the feature accepts the parameter, when you try and change the parameter value the feature does not update.
When I go back to the feature, the value of the parameter is shown not the parameter.
I have tried parameters as pcs also but it does not help.
Any help would be appreciated.
Replies (7)
KristianLaholm
I have the noticed the same problem with circular patterns.
My solution for now is:
  • Open Change Parameters
  • Find the Feature under Model Parameters
  • Enter User Parameter name under Expression
Now do NOT edit the Feature in the timeline.
The problem happens then you hit [OK] in the Feature Dialog box, looks like Fusion saves the value of the User Parameter not the Name of it.
([Cancel] seems to work to back out of the dialog box, if you open it by mistake)
Picante1
Thanks, I knew it was a bug 🙂 it used to work. I wonder if it's been logged. Thanks again for the workaround.
rishabh.bisht
Hi @Picante1, Thanks for bringing this to our attention. I can reproduce the bug on my end.
I'll escalate it to the dev team.
Sorry for the inconvenience!
Rishabh Bisht
Product Owner
Picante1
Of course no need to apologise, the product is great, thanks!!!
rishabh.bisht
This bug is tracked with this internal ticket - FUS-72357.
The dev team is actively working to address this issue.
Rishabh Bisht
Product Owner
rishabh.bisht
Hi guys, we just deployed an update (2.0.9009) that should fix this issue.
Please feel free to report back if you can still reproduce this bug. Thanks!
Rishabh Bisht
Product Owner
i can not download fusion 360
i have a samsung galaxy book s laptop
