Fusion should really be flagging this as over constrained but I guess all the dimensions have just overwhelmed the solver. If you have a right angle triangle with 2 equal lengths you should only need 2 dimensions to fully constrain it.
Not only have you dimensioned 3 sides and a 45° angle but on all three side you have a second set of dimensions (in affect dimensioning the line length twice). I guess you started with the triangle, if that's constrained with just the two 6.124" dimensions, if at any point it changes to unconstrained you have a problem.
You can see starting with a triangle and 2 dimensions you're fully constrained.
You are also adding to the complexity using 2 collinear lines when you could use a single line. Just add a point at the intersection if you need to dimension the intersection. If I was you I'd start again from just the triangle, add lines and fully constrain at each step and if you run into a problem like the main triangle changing to unconstrained come back here with the new design.
Mark
Mark Hughes
Owner, Hughes Tooling
