Typed in values in sketches do not move cursor to position
I've been having this issue for a long time. I want to say it happened after a specific update, but it's been so long that this behaviors been happening that I'm not sure if that is what caused it. It seems to happen on my laptop as well. Not sure if this is the expected behavior but while in sketches, if I try creating a line or a circle or anything else and typing in a value it will not actually extend to the target length/diameter. Instead, it locks the current length at it's current position seemly at random.
For example while in a sketch, I can create a line starting from one point and move a certain direction. The value in parenthesis will change based on how far it is from the originated point. Normally, you can just type in a specific value to make the line jump to that target length. It will also 'lock' this value, so you cannot incidentally shrink or extend that typed in value incidentally. However in my instance when I type in the value, it locks in the current length that I had moved my mouse to and does not extend to the typed value.
Maybe the best way is to show it through an attached video. Its worth mentioning that this behavior seemly occurs at random. Toward the end of the sample video, you can see after 3-4 attempts it actually does jump to the typed in length as should be expected.
Is this a bug? Is there something I am doing wrong? Is there a preference or option a missing somewhere?
