Announcements
Two different power nets connected to the same polygon pour
johnemoon
johnemoon
I was creating polygon pours on a power layer. I was creating one pour for +3.3V and another for +5V. After my original outlines for the pours, I decided I wanted to make a change. I adjusted the sides of the polygons several times. One area that originally was part of the +5V polygon I changed to the +3.3V. I thought I was careful to make a cutout in the +5V into which the +3.3V was going to extend. This was verified, in my mind, because there was not any cross-hatched area showing an overlap. Additionally, when I ran a drc it did not show any errors. However, when the manufacturer ran a check they got the indication there was a short circuit between the +3.3V and the +5V.
We went back to examine the layout and discovered that in the area that we changed from +5V to +3.3V there was an unmarked overlap in the two polygons. We only saw it when we turned on the 'show' and selected the +3.3V polygon and then the +5V polygon and we could see that there was an area of overlap. With this case the autorouter  connected both +3.3V signals and +5V signals to the same polygon pour. Thus, the short.
Two things are concerning. First, that the software even allowed me to do this. And second, that the drc did not flag this as an error.
Has anyone else come across this?
mt24000
Community Visitor
Community Visitor
Yep, occurred to me in a similar manner, but not with the auto router. I have a manual polygon pour on the top layer on some 5V rail with some manually placed vias to bottom layer. I also added a polygon on the bottom layer connected to 5V. Now I polygon poured the bottom layer with GND and it connects both nets without showing any errors.
I "fixed" it by adding a polygon cutout around my 5V polygon on the bottom layer.
g-andresen
Doesn't this topic belong in the electronics forum?
günther
