Announcements
Two center rectangles, rotated by user parameter
ross.kriel13
ross.kriel13
On a sketch; I need a rectangle (or square) inside a rectangle but I need to rotate the inner rectangle driven on user parameters. Having a tough time figuring this out; any advice?
jhackney1972
Here is a sketch that does as you ask.  Just change the Parameter - Inner_Square_Rotation
John Hackney, Retired
davebYYPCU
Set the position required with an Angle Dimension, Using the Parameter.
Might help....
ross.kriel13
thank you kindly. I see what you did there.
